Morph-based head
This type of head is created by the Face Creator.
The eyeballs and teeth are inside of the head like a real
person. Please refer to the
Creating Face From a Photo
section for more information.
You can also modify this kind of head by the Face
Creator in the Character Composer.
Sprite-based Head
Image head
This type of head is created by the Character Composer.
Each facial feature sprite is composed of image poses.
If you want to modify this kind of head, then you need to use the
Character Composer.
Get more facial sprites from
"Facial Component Library - Comical Style".
Vector head
Each facial feature sprite is composed of vector poses made by
tools that can generate SWF file, such as Adobe Flash.
Character Composer.
Hybrid head
You can mix up the two kinds of head to generate special character by both creating methods above,
as well as modification.
The facial features from the Face Creator and from the libraries in the Character Composer >> Head
can be puppeteered or set facial keys simultaneously.
Please switch to the Actor >> Head, and apply hybrid head from the
Head >> Hybrid library.
If you need to add expressions to the head of this type, then please refer to the
Solo Feature Selection Puppeteering section for more information.
