Open the downloaded Brows.dpa, Eyes.dpa, Hands.dpa, Mouths.dpa, Nose.dpa.
There are 5 elements (facial features and body parts) that have multiple poses. These elements are eyebrows, eyes, mouth, nose, and hands. The multi-pose facial features give the character different expressions and emotions when it talks; while the hand poses enable the character to produce different hand gestures. To observe the animation of these elements, please refer to the Changing Poses page.
Note: |
� You must follow the naming
rules as shown in the template. |
. Every
multi-pose body parts is an independent file.
Once you open a file, you will observe five heads presented on the stage, with
every pose stored in an individual layer.
You can change the background shape from the body file you create.
You can change every pose shape to match your own.
Place the pivot points where they can act as connecting points to the body.
Please adhere to the pose naming convention laid out in the template.
Note: |
There are only 5 angles that you
need to create for one pose of a specific facial feature (eyes, eyebrows,
nose, Mouth) and 10 angles for one hand pose.
Producing Roll-able Eyeballs in DrawPlus :
In order to make
pupils rotate in CTA 2, please adhere to the following rules.
.The pose with the
pupil must have 3 layers to accommodate the Mask, Pupil, and Image.
. The Mask and
Pupil layers must contribute to the mask function.
. Mask layers must
be locked.
. Please follow the
naming convention laid out in the template for all pose names.
Exporting multi-pose:
After all of the angle profiles have been completed, export
the data.
1. Save this template as another project file (*.dpa) first because you may need it for further fixing in the future.
2. Export the entire project as a
SWF file (*.SWF) by either File >> Export >> Export as Flash SWF.
