After the auto-conversion, you are able to adjust the rendered image without retouching the contents in the original iClone project by using the parameters provided by the Material Editor.
Base Emission = 7000 |
Base Emission = 17000 |
Base Emission - Red = 1.00 Base Emission - Green = 0.00 Base Emission - Blue = 0.00 |
Base Emission - Red = 0.00 Base Emission - Green = 0.25 Base Emission - Blue = 0.50 |
Note: |
Low IOR value. More light can pass through the surfaces and the medium of an object. Suitable for transparent or less reflective objects. |
High IOR value. Less light can pass through the surfaces and the medium of an object. Suitable for polished or metallic objects. |
IOR: 5 Exponent: 100 |
IOR: 5 Exponent: 10000 |
Note: |
The IOR feature must be turned up in order to experience more noticeable changes in the Exponent property. |
Fresnel: 0.3 Fewer faces in different angles reflect the environment. |
Fresnel: 1.00 More faces in different angles reflect the environment. |
Note: |
The IOR, Exponent and Fresnel parameters only work when the material settings of the object are set to Indigo Phong, Glossy Transparent and Phong or Glossy Transparent Based Blend. Otherwise, modifying these three parameters does not cause any material change when rendering in Indigo. |
The render result via Auto-conversion method |
The result by modification through the Material Editor (a glowing phong) |
Note: |
Please note that the original iClone project will not be influenced by these adjustments. |
