iClone's Indigo Render Plug-in prepares several optimized and pre-defined shaders for you to replace the original material of iClone objects for rendering in Indigo. Images below demonstrate just few of the results.
iClone Indigo Shader Presets |
Render in Indigo |
iClone Indigo Shader Presets Version 2 (New for 1.03) |
Render in Indigo |
Note: |
The objects applied with Auto Convert or Auto Convert v2 preset can be rendered with a wide range of materials settings. |
